Quick Farming Route
- Play on Torment I or higher, since Mythic Uniques won't drop below that level.
- Focus on Tormented Bosses instead of random overworld enemies.
- Run Duriel often, as he remains one of the better targets for Mythic Unique farming.
- Save Resplendent Sparks if you'd rather craft the ring later.
The big draw is simple: it helps strong builds stay active. If your setup spends a lot of resource, you'll notice the difference fast. Less waiting. Fewer awkward pauses. More time actually doing damage. Since the Ring of Starless Skies can be used by every class, it's not locked to one lucky group of players either. A Barbarian, Sorcerer, Rogue, Necromancer, Druid, or Spiritborn can all make use of it if the build fits.
Best Sources and Drop Details
MethodWhat to Expect
Tormented DurielOne of the most common farming choices for players hunting Mythic Uniques.
Other Tormented BossesUseful if you already have materials and want variety between runs.
Random DropsPossible on Torment difficulty, but the odds are far too low to rely on.
CraftingA steadier option if you have the right sparks, runes, and gold ready.
Crafting and Preparation
If farming refuses to play nice, crafting gives you another path. The Jeweler can create the Ring of Starless Skies once you've gathered the required materials, usually including Resplendent Sparks and specific runes. It's not cheap, and it's not something most players do on a fresh endgame character. Still, it removes some of the sting from bad luck. Before you commit, check your build. If the ring is only a small upgrade, your sparks may be better saved.
Final Thoughts
The Ring of Starless Skies is worth chasing, but it rewards patience more than blind grinding. Set yourself up on the right Torment tier, farm bosses with a group when you can, and don't waste materials on sloppy runs. If you're short on trading funds or boss prep costs, some players choose to buy D4 Gold to keep their farming sessions moving, but smart planning matters just as much as spending.
